نویسنده موضوع: استفاده از اوبونتو در گوشی اچ تی سی!!  (دفعات بازدید: 3811 بار)
آفلاین milad-x
  • ارسال: 128
البته شنیدم قبلش روی نوکیا N900 هم نصب و تست شده بود. نوکیا N900  برای تست توزیع های لینوکسی قابلیت های خیلی بیشتر و امکانات قوی تری داره
تا جائی که میدونم  اولین و تنها گوشی موبایل یا تبلت  دوال بوت بوده !! یعنی مثل کامپیوتر میشه یک توزیع لینوکس رو علاوه بر سیستم عامل لینوکس maemo5  خودش،   کنار هم داشت!!  ;D
اما یکی از دوستان زحمت ترجمه این مطلب رو بکشه خوبه:
HTC HD2 triple-boots WinMo 6.5 with Sense, Android 2.1 and Ubuntu
July 1st, 2010 byPeter
Mobile phones, Mobile software, Various
We probably won’t seen a GSM version of the HTC EVO 4G. Not officially anyway – the ever resourceful people from XDA Developers are busy porting Android and Ubuntu (yes, Ubuntu) on the HTC HD2, which WiMAX connectivity aside is identical to the EVO 4G…
gsmarena 001 HTC HD2 triple boots WinMo 6.5 with Sense, Android 2.1 and Ubuntu
The HTC Linux group (as they call themselves) is working on getting the Linux kernel working on the HTC HD2. From there, they are currently focusing on two OSes based around that kernel – namely, Android and Ubuntu.
Both are still works in progress, but they are actually functional – check out the video to see them in action. The Android version currently used is 2.1 Eclair and the Ubuntu version is 9.10 Karmic Koala. Actually they have a triple-boot setup – Windows Mobile 6.5 with Sense UI is still available after the hacking is done.
Ubuntu is meant to be used with a keyboard and mouse (which works, because HTC Linux have put a USB host feature on the HTC HD2). It looks like it can be controlled with the touchscreen too, but it’s not particularly usable that way right now.
Android 2.1 Eclair on the other hand seems to be working very well – there are still kinks to work out but they should be gone pretty soon. Keep an eye on the XDA-Developers forum thread or the this Twitter account for updates on the progress.
One tweet suggests that these ports will be able to run on other phones too, not just the HTC HD2. The Toshiba TG01 and the Acer S200 are on the list.
http://blog.gsmarena.com/htc-hd2-triple-boots-winmo-6-5-with-sense-android-2-1-and-ubuntu/
آفلاین eMan
  • ارسال: 1366
+1 ;)
جهت تماس با بنده یا از طریق فروم آرچ و یا از طریق وبلاگ آرچ بوک و یا از طریق ایمیل با بنده تماس بگیرید
