نویسنده موضوع: چگونه گیرنده x.vision dvb-t با ite it9135 را راه اندازی کنم؟  (دفعات بازدید: 4445 بار)
آفلاین بهنام …
  • ارسال: 1028
  • إن أحسنتم أحسنتم لأنفسكم وإن أسأتم فلها
خیلی توی وب جستجو کردم و خسلی کارها کردم (با کمک لینوکس نیوز و لینوکس تیوی) اما چون سر در نمیارم نتیجه هم نگرفتم. خروجی چند دستور را هم میگذارم. لطفا کمکم کنید.(من مبتدیم)
lsusb
Bus 002 Device 003: ID 048d:9006 Integrated Technology Express, Inc.dmesg
[   23.157350] it913x: Unknown tuner ID applying default 0x60<6>[   23.158851] usb 2-1.2: dvb_usb_v2: found a 'ITE 9135(9006) Generic' in cold state
[   23.180493] usb 2-1.2: dvb_usb_v2: Did not find the firmware file 'dvb-usb-it9135-02.fw'. Please see linux/Documentation/dvb/ for more details on firmware-problems. Status -2
[   23.180507] dvb_usb_it913x: probe of 2-1.2:1.0 failed with error -2
[   23.180532] usbcore: registered new interface driver dvb_usb_it913x
syslog
Aug 27 10:44:36 behnam rtkit-daemon[1503]: Supervising 5 threads of 2 processes of 2 users.
Aug 27 10:44:36 behnam rtkit-daemon[1503]: Successfully made thread 1826 of process 1800 (n/a) owned by '1000' RT at priority 5.
Aug 27 10:44:36 behnam rtkit-daemon[1503]: Supervising 6 threads of 2 processes of 2 users.
Aug 27 10:44:36 behnam bluetoothd[895]: Endpoint registered: sender=:1.49 path=/MediaEndpoint/HFPAG
Aug 27 10:44:36 behnam bluetoothd[895]: Endpoint registered: sender=:1.49 path=/MediaEndpoint/A2DPSource
Aug 27 10:44:36 behnam bluetoothd[895]: Endpoint registered: sender=:1.49 path=/MediaEndpoint/A2DPSink
Aug 27 10:44:51 behnam goa[2014]: goa-daemon version 3.4.0 starting [main.c:112, main()]
Aug 27 10:44:54 behnam bluetoothd[895]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/HFPAG
Aug 27 10:44:54 behnam bluetoothd[895]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSource
Aug 27 10:44:54 behnam bluetoothd[895]: Endpoint unregistered: sender=:1.30 path=/MediaEndpoint/A2DPSink
Aug 27 10:45:38 behnam dbus[879]: [system] Activating service name='org.freedesktop.PackageKit' (using servicehelper)
Aug 27 10:45:39 behnam AptDaemon: INFO: Initializing daemon
Aug 27 10:45:40 behnam AptDaemon.PackageKit: INFO: Initializing PackageKit compat layer
Aug 27 10:45:40 behnam dbus[879]: [system] Successfully activated service 'org.freedesktop.PackageKit'
Aug 27 10:45:40 behnam AptDaemon.PackageKit: INFO: Initializing PackageKit transaction
Aug 27 10:45:40 behnam AptDaemon.Worker: INFO: Simulating trans: /org/debian/apt/transaction/4527d47759f24f6eb50399c1ceacd1c4
Aug 27 10:45:40 behnam AptDaemon.Worker: INFO: Processing transaction /org/debian/apt/transaction/4527d47759f24f6eb50399c1ceacd1c4
Aug 27 10:45:41 behnam dbus[879]: [system] Activating service name='com.ubuntu.SystemService' (using servicehelper)
Aug 27 10:45:41 behnam dbus[879]: [system] Successfully activated service 'com.ubuntu.SystemService'
Aug 27 10:45:44 behnam AptDaemon.PackageKit: INFO: Get updates()
Aug 27 10:45:45 behnam AptDaemon.Worker: INFO: Finished transaction /org/debian/apt/transaction/4527d47759f24f6eb50399c1ceacd1c4
scan ... it-Tehran
scanning /usr/share/dvb/dvb-t/ir-Tehran
using '/dev/dvb/adapter0/frontend0' and '/dev/dvb/adapter0/demux0'
main:2284: FATAL: failed to open '/dev/dvb/adapter0/frontend0': 2 No such file or directory
w_scan -F
w_scan version 20111203 (compiled for DVB API 5.4)
WARNING: could not guess your country. Falling back to 'DE'
guessing country 'DE', use -c <country> to override
using settings for GERMANY
DVB aerial
DVB-T Europe
frontend_type DVB-T, channellist 4
output format vdr-1.6
WARNING: could not guess your codepage. Falling back to 'UTF-8'
output charset 'UTF-8', use -C <charset> to override
Info: using DVB adapter auto detection.
main:3079: FATAL: ***** NO USEABLE DVB-T CARD FOUND. *****
Please check wether dvb driver is loaded and
verify that no dvb application (i.e. vdr) is running.
خروجی دیگری هم اگه لازمه بگید. چون خودم با کارهایی که linuxtv گفته بود دیدم خیلی تغییرات در سیستم ایجاد شده ولی سر در نمیارم.
آفلاین بهروز رمضانی
  • ارسال: 1111
  • Kakashi Hatake
    • ابونتو نیوز
راه اندازی این کارت با این مدل چیپست خیلی هم راحت هست ، برو به لینک زیر و کامل راهنما را دنبال کن .
http://www.linuxtv.org/wiki/index.php/ITE_IT9135/code]
در یادگیری و استفاده از خط فرمان کوشا باشید چرا که رستگاری شما در آن است.
آفلاین mahdiar
  • ارسال: 921
